KZN185 flashing brake light
  • KZN185 flashing brake light
    I have a 1996 KZN 185 and ever since I've had the car the brake warning light (NOT the ABS light, the red one bottom left) has flashed when the vehicle is moving. It's speed related, as at walking pace you can see the pulses, but over about 15mph the light just stays on. I've clocked the light at six flashes per wheel revolution.
    Car has had a new master cyl, discs and pads, and all works well. Any ideas please ?
    Yes, is the level in the brake fluid reservoir below min by any chance?
      No, it's topped up. I had the same issue with a different master cylinder as well
        i think you will find that the giggle pin is
        rubbing on the laughting shaft causing it to
        pick up a signal from passing sheep horns
        or from the vast outer space debri left by the
        yanks and ruskis or as everybody else will blame
        BREXIT
        or more than likly you have a bad contact
        the old git
          it will be the giggle pin for sure!
          Old enough to know better but then again.....
            glad to see somebody
            else witn a sence
            of humer
            my spelling is getting realy bad
            the old git
