Here's a question for ya, as most of us know the gauges on the surfs tend to bend the truth a little, i currently only have the fuel and temp gauge working to a trustworthy level.
I was thinking of fitting new gauges, as in completely remove the toyota instrument cluster and fitting gauges from a different brand, now i know the speedo signal is digital and it all sounds griefy trying to splice into old sensors etc
does it sound crazy to just do away with the toyota signals and just lay new ones i.e. rev gauge wired to read the HT leads or an inductive sensor setup on a shaft somewhere to transmit a speed signal?
your input will be handy
thanks
thanks
