Abs diagnostic test
  • Abs diagnostic test
    Hi I've searched for abs diagnostics and nothing came up. I apologise if I'm asking the same question that's already been answered but just getting used to the forum.
    How do I carry out a check because my abs light is on, thank you
    As per the video I posted in the other thread.
    Short TC-E1 and count the codes.
    TOYOTA ABS CODES
    11 — Open shorted relay circuit. Check modulator wiring harness, solenoid relay, solenoid relay wiring harness and solenoid relay connector.
    12 — Short in solenoid relay circuit. Check modulator wiring harness, solenoid relay, solenoid relay wiring harness and solenoid relay connector.
    13 — Open pump motor relay circuit. Check modulator wiring harness, pump motor wiring harness, pump motor relay circuit and pump motor connector.
    14 — Short in pump motor relay circuit. Check modulator wiring harness, pump motor wiring harness, pump motor relay circuit and pump motor connector.
    21 — Open or short in ABS solenoid for right front wheel.
    22 — Open or short in ABS solenoid for left front wheel.
    23 — Open or short in ABS solenoid for right rear wheel.
    24 — Open or short in ABS solenoid for left rear wheel.
    31 — Problem in right front wheel speed sensor circuit.
    32 — Problem in left front wheel speed sensor circuit.
    33 — Problem in right rear wheel speed sensor circuit.
    34 — Problem in left rear wheel speed sensor circuit.
    35 — Open in left front or right rear wheel speed sensor (WSS) circuit.
    36 — Open in right front or left rear WSS circuit.
    37 — Faulty rear speed sensor rotor.
    41 — Battery voltage too low or high (under 9.5 volts or over 16.2 volts). Check battery and charging system.
    51 — Pump motor is locked or pump motor circuit is open. Check pump motor, motor relay, wiring harness and modulator ground connections.
    "Always on" (no flash codes, just a steady light) — Malfunction of ABS module.
    To clear fault codes, leave the jumper in place between terminals Tc and E1 with the key on, then pump the brake pedal eight or more times in three seconds or less. When codes are erased, the ABS light should flash two times per second.
    More Lift.
    More Tyres.
    More Engine.
      Ye sorry about that I didn't see the link.
      Thank you I'll try that when I'm off on Friday
      Cheers rob
        Hi there, I've shorted TC and E1 to try and find the abs codes but when I turn the ignition on the abs light just stays lit and the red air bag light flashes, just wondered if you had any ideas, thank you rob
