hello all once again, the difficult cold starts of the Surf was finally diagnosed to faulty passenger side battery (my surf is LHD). Glow plugs weren't getting enough juice in the morning, and hence the hard starts.
the current batteries are cheap GS 70AMPs (one is about a year and a half old, the bad one is almost 4 years old). i have searched the forum and many posts recommend between 70 and 80amps for the surf. here is the problem, I can only find 60AMP batteries at my price range. they are from a company called Yuasa, which, with my limited research, has a good reputation. they are rated at 370CCA and go for about US$125. The 75amp SMF Panasoic (690CCA) goes for almost US$160 and another Silver-Calcium (750CCA) one goes for almost $220, which is just ridiculous.
so my question is can I get away with the two 60AMP batteries or should bite my teeth and buy the 75amp Panasonic?
