I've searched many threads but cannot find my particular problem.
Central locking works fine but now not on the rear door that remains unlocked. As an emergency measure I have disconnected the linkage so that the rear door can only be opened from inside.
Looking at the wiring I can trace two wires that go from this complex of connectors to the latch mechanism.
Blue with White trace & Black with Yellow trace.
I assumed that this would supply some sort of solenoid that is operated by the central locking. With the relevant connectors uncoupled with an ohmmeter I can detect no circuit. On the other connector when flicking the central locking on & off no voltage appears on the corresponding feed wires.
Bit frustrating to find this as on holiday. I can just about operate rear door by pushing on a mole wrench clamped to the linkage arm.
All fuses are intact & the rear window & wiper operate as normal. All the connectors are clean, free of corrosion & I can see no wire breaks or compressions.
I have sprayed WD40 up into where the linkage goes in case some mechanism is not quite going back where it should. Rather mystified as the only eligible source of power to operate a solenoid has nothing & anyway the two leads to this supposed solenoid are open circuit.
Or perhaps I am barking up the wrong tree? Any help gratefully received.
