Low fuel warning light stuck on
  • Low fuel warning light stuck on
    .....as per the title, the fuel gauge is perfect but the light has been stuck on since I ran it very low a few weeks ago.
    I've had a google/search around but can't find anything that doesn't relate to a faulty gauge or sender and the needle being out. Mine is spot on.
    Any help out there?
    Petrol, diesel, 2.4 or a proper one?
      Haha........ 2.7 petrol
        Might help...
        https://drive.google.com/file/d/0B17...ew?usp=sharing
        ...always assuming I know how to share that right.
          You posted in wrong section
          Try hairdresser section
          Sounds like a break in wiring to lamp
            Probably the sensor assembly, separate to the sender float. I think it's a thermistor that may have just given up. Not sure where the tank access is, is it under the rear seat?
              I think it is...though if you have a body lift that doesn't matter
                Ours has an amazing body lift at the moment, about 4ft. Trouble is, the chassis is still right up,against the body and the wheel are in the air.
                Hope your get your sensor sorted Rob.
                  You fitted VTOL!?
