I have a LN130 that cut out when driving of drive that looked like a fuel problem had dianostic done to day and they came up with fault code 48 that's not listed anyone any ideas or is it just case of replacing fuel pump.
Fault code 48
Hi jez,
Have a look below, code 48? could it be code 4 & 8?
hope this helps
http://www.hiluxsurf.co.uk/showthread.php?t=758
Gman.If it aint broke, keep goin' till it is.
Hi jez,
Would'nt of thought so, I ran mine with a code 4 for weeks,
have a look at the wiring around the injector pump, a broken
wire in the alarm, in that area stopped mine some time ago.
hope this helps.
