hi guys me again my surf is giving me grief on starting I put the key in make sure its in park touch the brake pedal turn the key all the lights come on but doesn't start. no noise nothing give it 2 or 3 goes and will eventually start. It has an immobiliser fitted the type which u touch with a fob but I believe this to be bypassed because I have never had to use it and don't have the fob.and was ok for the first week or so but now playing up any help thx colin
starting
If you can reach it you could try to jump the starter motor straight from a battery to see if it works or not.
If not then it's probably the starter contacts burnt out, I got some off ebay for under £20 that did the job, much cheaper than roughtrax as you don't usually need all the other bits in their kit just the copper contacts.
If the immobilizer has been "disconnected" someone might have just cut it out and twisted the wires back together again and they've come apart.
Check under the dash for any bodges.
