Hiya,
Right i have a Gen 2 1993 Jap import, the heated rear window doesnt work...
So after reading on here and while replacing the rear window motor, i noticed that the wires had snapped... so i set to replacing the wire and put new "female" spade connectors on the end of the new wire.
Then found that one of the "male" spade connectors has snapped on the glass...
Is there anyway of repairing the connector on the glass or is it a case of getting a new rear window???
