hi all
not posted 4 a while.
a buzzer has started to come on / intermittently
scared the hell out of me first time , same as the ignition warning buzz + all the warning lights come on !!
it is intermittent , I think revs related comes on with less revs . on at idle , off with higher revs .
is it the alternator, belts poss a bit loose , need to check them , also ill check the volts output .
wots the 'idle up ' I've read on here ?
so with 800+ revs ish I should be 14.4 volts if its charging proper ?
tom
tom
