hello fellow surfers I have a problem with heated rear window. it was working fine and now nothing. the switch light goes on off and the fuse is good.Would this be a relay problem if so were is the little !!!! can any body help cheers:
hello steven i will be checking wiring weekend. now i know common fault have seen were wire goes up down! just did"nt know if was relay!!!! so cheers gaza
