Rear window switch issue
  • Rear window switch issue
    Here's a conundrum for you, my back window opens with the key in the tailgate, but if I use the switch up front it stops after moving an inch.
    Any ideas?!
    If I like it, Bushwhacker doesn't. :-)
    Not a clue...but you can pull the switch apart and clean the contacts easily...there's a roll pin in the middle you can knock through and that's it.
    I'd look at using a bit of wire to bridge the connections in the plug to the switch, if the window works bob is your uncle, if not it's not the switch.
