Hi can anyone help me please.  I've had my surf for nearly a year now and I'm so chuffed to bits with it.  I just have one problem.  it has a cobra 3190 alarm fitted and I only received one key/fob with it.  I got another key cut and bought a new fob but ....... I can't/don't know hoe to set the fob to work.  I've been in touch with Cobra and they have been fantastic but I'm still struggling with it.
I don't have a pin number for a start.
I can't get a serial number as my mechanic has given me everything the alarm has written on it (which I've told cobra about). I've read somewhere about a touch key (no idea what this is so don't think I've got one) on the dash I have a small (about the size of a ten pence piece) led (red) with a tiny button under the led (which I assumed was something to do with the alarm) it does flash when using the fob. The fob is a bit like a teardrop shape with two grey buttons on and a led in the middle.
PLEASE HAS ANYONE ANY IDEAS HOW TO MAKE THE NEW FOB WORK????
Could I take the inside out of usable fob and just swap it with the new fob ie: so original working code etc but in a new case???
Thanks very much for looking and an even bigger thank you if you can help.
Linda
Linda
