Hi folks I've got bored with use my key to unlock the hilux so was looking to fit a remote central locking kit. Now I have a kit that is a simple box that takes a pos and neg of course then signal wires to operate the open and close functions on the fob. I was thinking of wiring these signal wires into the door lock button as it will be easy to get to and should be easy to wire in.
Had a little look at the wiring loomon this yesterday and looking for power and it appears to me that the door lock button seems to work on a negative means as when it is operated for open or close a wire that did have 12v running through it then has 0v. Am I on the right lines as I've looked through my Haynes and can't seem to find the wiring diagram for the door lock switch.
Help is greatly appreciated
Marty
Marty
that should help things then I think I got all the details on
