hi BW
i inspected some of the tale gate area today, i wanted to fit spoiler but due to rain pulled out. i removed the following bit n pieces, tale gate internal plastic cover and body plastic covers from rear of truck also rubber cover that protects the wires between tale gate and body and i couldn't locate an additional loom, any idea where this is tucked away ? just to add, i did inspect all the wires that went to what looked like a small ecu unit located in the tale gate, from that they branched off to blocks.
