hey guys,
the plan tomorrow is to re-wire my spot lights and fit some very small lights into the grill below the bumper. now i've got no problem wiring the whole lot myself, have all the bits here waiting to go. while having a good look around earlier today, i noticed there are some spot light wires already in place, they're covered in a cibie sleeve (there was a cibie switch on the dash when i first saw her) and run from battery to fuse to relay to lights etc. but have been unceromoniously chopped off on the way thru the bulk head. i'm thinking it would be a shame not to use these wires as the hard works already been done....... my question is this.....
at the switch end i have black, blue, white and yellow wires. down below at the light end i have black, blue and yellow wires. the 'little' lights have 2 wires (supply and earth) the switch has 3 (earth, load and supply) which ones should (can) i connect where to make it all work...???
any help would be much appreciated.
see ya'll
Planty
see ya'll
Planty
