Kick Down Switch 1UZFE Lexurf
  • Kick Down Switch 1UZFE Lexurf
    £3.00 Heavy Duty Push to Make foot switch from Maplins
    Free upvc window catch.
    offer up under accelerator, mark postion so switch touches the underside of the pedal, not the bar.
    You will need to move the accelerator pedal out the way. Remove one bolt, and loosen the other - it will swing out the way.
    Drill holes and seal.
    Earth the switch and send a lead back to the ECU.
    Job Done.
    www.johnthebuilder.info
