rear window demister
  • rear window demister
    help my demister has stopped working, the dash switch works ok though.
    Demister
    Mine stopped working a couple of years ago. If you remove rear panel there isa connector on bottom of glass. It should have 2 wire connected to it. one of mine had broke off. I gave it a gentle clean up & re-soldered it back on.
      As above, but also because the wires flex as you use the window they can break inside the insulation, can be a bugger to find.
