headlights and high beam
  • headlights and high beam
    HI
    Can someone point me in the direction of a wiring diagram for relay operated head lamps that also illuminate the high beam indicator?
    I think it is as simple as using terminal 87 power and 85 ground ? but would like a diagram to check with before I start blowing fuses
    TA
    Eat.Sleep.Surf.Repeat.
    Do a search for threads by Maverick
    I seem to remember he put a full wiring diagram and parts list up
      I have searched and failed
        Search again with your high beams on.
          This help?
          http://ww2.justanswer.com/uploads/Cl...ingdiagram.jpg
            That should do nicely
            If I wire it that way then the high beam indicator should work as it will "see" the resistance of the coil.
            I think I have everything I need now
            my home made wiring loom and relays
            Osram nightbreakers
            New H4 connectors
            And some spare fuses just in case.....
