Hi i have a 1991 SSR-X 2.4l turbo auto diesel.
When playing around with the relay's above the drivers side fuse box i accidently damaged the top one. I have thoroughly checked it out and the relay seems fine ( i opened it).
Now my symptoms are as follows:
Instrument Panel - Not working
Rear Window - Not working (from drivers switch only)
Auto Box - Not changing gears (staying in 1st)
Gear Stick - Not wanting to get out of park without using the over ride button
I have tested the switch and it's fine, i have tested the part the switch came from and there is no switch power going to it. Only current power.
Im not sure if it is supposed to get switch power or not tho...
It honestly feels like i have blown a fuse somewhere but i can't find any blown fuses.
I have the 4runner/hilux manual and these relay's arent in any of the diagrams.
Can someone tell me what this relay is please?
The one below it is the "main relay".
There are 3 relays and a 30amp fuse next to them. (tested this fuse and it is fine).
IM GOING CRAZY!
IM GOING CRAZY!
