The tail gate window has recently started to randomly goes down. I replaced the relay unit thinking that might be the problem. Last night the window was up, this morning it was down. Not sure if it is related but the rear speaker constantly clicks when you turn the ignition key to the first click/aux, but stops as soon as the ignition is switched on. However it has always done this. The clicking stops if I pull the connector block off the tailgate window relay unit. The two don't seem to be connected in terms of wiring.
Any ideas?
Thanks
Any ideas?
Thanks
