blown fuses :(
  • blown fuses :(
    hello im after some guidance if u please! i have a kzn185 surf and an intermitant fault a blowning fuses on the 15amp windows heater and speedo circuit ! i have checked the connections visually looked at wiring etc and when i swap the relay its fine for ages then starts blowing them again ! did it yesterday now swapped to the first relay and fine again i have a spare fuse box from a breakers hence spare relay any pointers ?
    blown fuses
    just an update after some investigating i traced the problem to the centre console and the handbrake ! which when taken off before driving away was shorting some loose connectors which are now taped up and secured :P and here me looking for ecu s etc
