Cheers! Hmm... £30 + delivery sound fair?
3rd Gen heater control unit
Hi Baz just call it £30 all in Baz mate if that's ok with you? I will need your address mate though, This is my email
Email replied to mate..Last edited by tonupteabag; 20 April 2012, 10:39.I'M ALWAYS IN THE SH'T, IT'S ONLY THE DEPTH THAT VARIES!!!!!!!!
3rd Gen Heater Control Bulbs
Going to bite the bullet and get mine fixed. The actual part numbers requried I just couldn't find on here.
However, I've dug out the following from google:
So the part numbers I need are apparently
81850G AKA toyota 81850-35010
Has anyone found the same bulb under a different code in the UK?
The ones in the push-buttons are dim - In daylight, I struggle to see if the A/C is lit or not. There doesn't appear to be a part number for these either. I guess they can be cleaned up?
I'd get a popeye fix done but I need the truck every day for work.
Hope the above info is useful, the full link to the diagram above is here:
http://www.jp-carparts.com/toyota/pa...ype=6&fig=8715
Click "Image 2" tab.Last edited by J i m s t e r; 9 November 2015, 13:20.Surf if you got a wave. Wave if you got a Surf.™
Update: I think the heater bulbs : toyota 81850-35010
are also known as Neo wedge T1's.
Also seems that where no separate bulb part is listed, the bulb is non-service and therefore you need the whole button/switch if going for an identical Toyota part.Here you can see what the lamp might be called in other shops.
Neo wedge 4.6 mm: Neo wedge T1, Stanley T3, Volvo art id. 9148906, 9148908 & 30739356Surf if you got a wave. Wave if you got a Surf.™
