Yes I know, I know. New fangled electrickery and all that!
But the ABS warning light keeps coming on. First happened a couple of weeks ago, killed ignition, restarted, light gone. Forgot about it.
Came on again yesterday on the way back from the Plains. Came on a few times and disappeared a few times. It was okay late last night and this morning but came back on the way home from work.
Surf is a 3 channel brake system - fronts are independant and the rear has one brake line between them.
Only other thing to go wrong recently is a rear hub seal - one of the drums is full of oil and grease. ABS sensor is around the same place.
What do I check for?
Wheel sensors? How?
Earthing fault?
Something else?
My bank balance?
The bottle of JD?
Would be nice not to go to the dealer
Rob
Wheel sensors? How?
Earthing fault?
Something else?
My bank balance?
The bottle of JD?
Rob
