Rear window prob's
  • Rear window prob's
    Hi all,
    I have been having a problem with my rear window periodically stopping working (or should I say it periodically starts working). It works fine from the key but the button in the front just stops working, have had the dam thing out to see if there is a loose connection anyware but cannot see one, have also tried to see if there is a pattern to the problem, hot weather ect, but cannot pin it down to anything. Anyone had anything similar with there Surf.
    Simon
    Do you realise that the window lock button also locks out the rear window control from the dash but not the key? You wouldn't be the first or even be the last to be caught out by this!
      I seem to have found the connection, two kids in the back faffing with the windows, I put on the window lock, Now I feel really stupid.
      Thanks for your help
        No worries, been there myself!
