Ok where is the fuse for the cig lighter, cant find any answers on here someone must no kzn185 3rd gen taken out every fuse in footwell and engine bay please help
Hi yes of course i will share
Well on the back of the cigarette lighter there is a fuse wire you need to replace that job done,i searched high and low for the ###### fuse,
take the cigarette lighter right out and you can see the little fuse wire on the back hope this helps someone else cheers Guys
Chris,got something similar on my truck,but the only wires on my lighter are the live feed,an earth and the feed to the light bulb,just so I know I am not going doolally,what colour,or where did it fit,thanks,Alan
as a total side issue but related to the ciggy tray, why is it that mine has a light that seems to come on and off when it feels like it..some times it lasts weeks on..then it goes off for a while..im thinking loose bulb lol always works in romania second we get to uk it decides to die
arent you on a different voltage in Romania,only joking,try taking the bulb out,open the "pins" a little and it should work
