problem with brake lights and gear selection.
When you push the brake pedal down when the vechile is in park it should let you be able to select a drive. I have replaced the brake pedel switch which is not faulty. I pushed the red button on the transmission box the select drive as it would not release as normal with foot on brake but my brake lights dont work. Is there another relay, fuse etc i have missed or is it a wiring problem. It only happens intermittantly which is a pain.
I have a 92 auto 2.4 ssrx. LN130
Hope someone can help.
