My 4wd is not working on the button (high range), it's working if you switch to low range.
There is no click so I'm guessing it's either a fuse, a broken wire or the relay, rather than a vacuum issue.
Where is the correct fuse?
Where is the relay?, I seem to remember hearing a click from the centre console area?
It was working up until a few weeks ago
