Hi guys (and butch gals if you're driving a Surf!),
My Surf has, all of a sudden, started going haywire on the electrics. Symptoms are:-
Rev counter needle shows much higher revs whilst temp gauge needle shows higher temp. At the same occurrence, the window winder motors run very slowly & cause an even higher rev needle exaggeration/temp gauge reading.
Autobox does lumpy gearchanges at transition speeds/torques (OK gearchanges at hard & defining speeds/torques).
I do hear a click (relay click?) in the passenger LH kick panel but dont think its coming from inside the ECU. Is there anything I should be checking out regarding this click? Batteries are both good/nearly new.
Sometimes the faults aren't there, usually at a standstill/tickover but a couple of secs of driving and all starts off again.
Mike
Mike
