Light problem
  • Light problem
    I have a problem I have never come across before and I am stumped.
    Only one headlight (the drivers side is working) But both work on main beam.
    No tail lights, but have brake lights. No instrument panel lights, but all warning lights light up with the ignition on. I have checked the obvious fuses.
    Could any expert please point me in the right direction.
    TIA
    Have you tried replacing the bulb ?
      Bulbs are OK, spots and fog light are also inoperative, along with the audible lights on warning. I suspected a loose earth somewhere, but would the one headlight still work if this was the fault?
        TIA
        Gauge fuse in the fuse box down by the accelerator.
          Cheers for that will check tomorrow
