Does Anyone Have The Ecu Pin Outs For An Automatic 91 Surf With A 2lte Engine?
2lte
i think these are the ones you need
Here are the codes for a 2LTE diesel.
1 - Normal
2 - Turbo boost pressure sensor
4 - Coolant temperature sensor
5 - Correction resistance (Pump)
6 - Pump speed sensor (Pump)
7 - Throttle position sensor
8 - Intake air temperature sensor
9 - Vehicle speed sensor
10 - Starter switch
11 - Switch sign (Vehicle not in P or N or A/C on)
12 - Timer control valve (Pump)
13 - Crank position sensor(\__/)
2lte Wiring
Thank You for your help,
although I need a wiring diagram showing the wires going to the ecu and were they come from. I'm trying to check the wiring from the Coolant Temp Sensor to the ECU but don't know which pins they go to at the ECU.
2lte ECU ECT Pinouts
Does anyone have the pinouts for a 2LTE ECT? I have the ECU pinouts, but am stuck without any details on the ECT.[B]Offroad Pakistan at [URL=http://offroadpakistan.com]offroadpakistan.com[/URL], by the 4x4 Offroaders Club Karachi.[/B]
