Im preparing to install some gauges. ( water temp and ATF temp) I need an " ignition live" and the easiest one to access that Ive come across is the feed for the old hard/soft suspension switch. Is it OK to piggyback from there ? If it makes any difference I dont have the adjustable suspension since installing the + 2 roughtrax sus lift. I,ll also need a headlight/sidelight feed. Is it ok to take that from the fag lighter light connection.?
Gauge Install
As far as i know Alex the gauges use very little current so it should be ok, on mine i removed the steering columb shroud and used a test light to find an "ign" lead, it' was a thickish wire so in the course of rewiring a load of stuff i connected a lead to this wire and ran it to a fuse box supplying all the live side, then take verious feeds from the other side of the fuses and fit an appropiate fuse, for your purposes tho the wire you found will do fineOriginally posted by Bogus View PostIm preparing to install some gauges. ( water temp and ATF temp) I need an " ignition live" and the easiest one to access that Ive come across is the feed for the old hard/soft suspension switch. Is it OK to piggyback from there ? If it makes any difference I dont have the adjustable suspension since installing the + 2 roughtrax sus lift. I,ll also need a headlight/sidelight feed. Is it ok to take that from the fag lighter light connection.?Too young to die and too old to give a toss
Use the +ve from the lighter....
Easy to identify and get to. Plus you can use the light feed from there too as suggested so all your wires run to the same point for neatness!
My CB and TV tuner run from there, and it is "switched" with ignition.
If you want to run from the switched ignition as Popeye suggested, there are two wires to choose from, one is black red (I think?), the other is black yellow. The thick whiteish ones are constant 12v and the blue red is the accessory. Yes it is very sad that is from the top of my head
More Tyres.
More Engine.
Thanks all. I ended up taking an accesory live from the radio, and using the fag lighter for a lighting live. Gauges are all in and water temp sender installed. Works fine but I wish Id gone for different gauges ( digital) Too late. not changing them nowСви можемо
Nothing wrong with a nice "bling" analog gaugeOriginally posted by Bogus View PostThanks all. I ended up taking an accesory live from the radio, and using the fag lighter for a lighting live. Gauges are all in and water temp sender installed. Works fine but I wish Id gone for different gauges ( digital) Too late. not changing them now
Ye those pics look greatOriginally posted by Bogus View PostThanks all. I ended up taking an accesory live from the radio, and using the fag lighter for a lighting live. Gauges are all in and water temp sender installed. Works fine but I wish Id gone for different gauges ( digital) Too late. not changing them now
IanOriginally posted by POPEYE View PostAs far as i know Alex the gauges use very little current so it should be ok, on mine i removed the steering columb shroud and used a test light to find an "ign" lead, it' was a thickish wire so in the course of rewiring a load of stuff i connected a lead to this wire and ran it to a fuse box supplying all the live side, then take verious feeds from the other side of the fuses and fit an appropiate fuse, for your purposes tho the wire you found will do fine
Do you think that using RJ45 cable would be good enough for the signal between Sender units and the displays? the amount of cable on my Boost Gauge and Temp Gauge is little to nothing and getting a multi core cable that will go through the dash into the engine bay is a right pain in the "provebial".
taAlways room for more power!!!!
Apart from the grommet where all the main cabling goes through, I have another, just above and outboard a bit from that one, where my immobiliser cables go . I managed to run all my cables through that one with no difficulty at all. Im guessing RJ45 would probably be allright as the signal wires are probably no " fatter"Originally posted by madmanc View PostIan
taСви можемо
