Hi there folks. This may seem like an obvious question but here goes anyway.
The batteries on my Surf are going flat pretty quickly (in a few days with normal daily use of the truck). I suspected that it would be that they weren't charging due to the alternator finally giving up the ghost. I was warned that it wasn't working properly not long after I bought the truck 2 years ago and called out the breakdown service folks who tested the the voltage across the batteries with the engine off/idling/revving.
Given the warning signs I'm expecting it to be the alternator but I'm wondering why the warning light on the dash isn't letting me know this (I assume there should be a warning light or beep or something that should flag a failing alternator given the posts I've looked at elsewhere on the forum about this problem).
All I have done so far is test the voltage across the batteries (fully charged and just put back on the truck):
Engine off: 12.8v
Engine idling: 12.8v
Engine revving hard: 12.8v
Now for the question...
Are there any fuses/relays I need to check before I assume the worst and replace the alternator?
Any other helpful advice will be most welcome.
Thanks in advance, folks.
Engine off: 12.8v
cos I needed to run something a lot cheaper on fuel. With a bit of luck I'll get another one someday cos I absolutely loved the wee beasty.
