the last fe days i have been getting the"click" only when i have been starting the truck up which i have put down to solenoid or motor brushes.
im now questioning that as i have noticed a reduced cranking speed and lights going a little dim on dash when turning over.
my truck has 2 batts, would one batt that goes t*ts up be the cause of my starting issues or is it batt and starter ??
EDIT :
i assume that batteries that are less than 12v are duff either on load or not
also, what amps should my alternator be kicking out
many thanks
EDIT :
many thanks
) that once started your truck will run and start all day but get worse over a few days then your most likely looking at a couple of shot batterys.
