My engine check light is on and I also know that my glow plugs are not glowing. I am in the process of checking the glowplug relay. Other than that, the surf runs fantastic as it should with a new engine and head.
I have a Snap on scanner(MT2500). Is this useable on a surf or otherwise, how do you extract the fault codes? I know I have seen it before on here but cannot find it. Any help greatly appreciated. Ta.
After it is fixed, surf sadly has to go. Missus said 4 cars was too much. Personally, I dont have a problem with it!
