Indicator relay
  • Indicator relay
    Can someone that has a diagram of the third gens. under the dash fuse box layout please post it.
    I can't locate the indicator relay, I can hear the little bugger clicking away, but can't get my hands on it.
    私のホバークラフト は鰻が一杯です。
    it might be behind the kick panel in the drivers footwell. or under the bonnet
    SWIFT AND BOLD
      It's under the dash , drivers side, I think as I can hear the clicking.
      I've got the kicker plate out, the lower dash and still cant find it
      私のホバークラフト は鰻が一杯です。
        EPC diagrams don't show much apart from being near top centre of junction box on drivers side.
          Cheers Nev
          私のホバークラフト は鰻が一杯です。
            Did you find it? Is it an electronic or thermal relay?
            I'm guessing it'll be electronic. I'm planning on LED'ing my indicators now I've done my high level brake light, and want to adjust it to give a sensible flash rate rather than fit ballast resistors.
              Oh just a quicky mate, you do have a glove box light, it has a little round plastic grill thing over it above the glove box, got side tracked the other day by robbing tw@ts so forgot to mention it.
                Ahhh. I did feel something, but it was dark, and the light of a thousand suns doesn't get in there. Must be bust then - I'll have a look.
                  Not looked again since the last post as been getting home after dark.
                  I'm assuming is electronic as well.
                  Found a good site for LED bits and bobs, including indicator relays.
                  Link is on my ipad, I'll post it later.
                  私のホバークラフト は鰻が一杯です。
                    I was toying with just making a simple flasher circuit and driving a conventional relay from that.
