12volt ignition switch?
  • 12volt ignition switch?
    Hi guys I'm fitting a new temp gauge & I need to tap into the 12v ignition switch can anyone tell me which one/colour it is please.
    Thanks si.
    Right I've done a test & I appear to have 2 switched lives "is that right", both dead when ignition off & both live when cranking & engine running, anyone shed any light.
      Found it, all is well.
        Good job si.
          Hey thanks, I couldn't have done it without you.
              Well no one was around to answer my quesions so I figured it out on my own.
              Took a bit longer but I got there in the end.
              Oh vince can you answer to my other thread cos all I'm getting is jokers.
