Hi all i am about to fit a new alternater to my 3.0 nd gen surf . some advice on what they are like to fit. it never started a few weeks ago so i bought 2new batterys and it started fine for a week then it drained them cheers
Fitting new alternater
alternator remove replace
hi easyish job
i got a new one from roughtrax and 2 belts as well
them followed this link http://www.toyotasurf.asn.au/techsite/alternator.htm
Much easier than that on a 3.0 2nd gen. Remove driver side battery (for better access) disconnect the other battery.
Slacken the 2 bolts (not as bad as they appear to be once you find them)holding the alternator then wind the adjuster in so you can get the belts off. Take the 2 bolts off and disconnect the plug and remove the 10mm nut and with some wrangling will come out
Thanks for your help job done working fine nowOriginally posted by rbaz View PostMuch easier than that on a 3.0 2nd gen. Remove driver side battery (for better access) disconnect the other battery.
Okay, whats the trick to removing the grey wiring plug - mine seems stuck! There is a flexible "lug" on the top side which moves, but doesn't want to release anything.
Any tips?
Sorted it.
used some special grease I found in my elbow...Last edited by Wolfracer; 2 August 2011, 10:29."B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
www.johnthebuilder.info
