Electric Diagrams for anyone
  • Electric Diagrams for anyone
    I have some electrical diagrams for surf 1993 (ranges from 91-95) gen2
    Post on here what you would like with your email as the files are too big to upload on here, and iwill get back to you if i have them.
    Hi fella do you have the 4wd system diagram? I have no power to the motor on the transfer case. Cheers. Tractorman.tc@googlemail.com
      http://www.toyotasurf.asn.au/techsit...0disconect.pdf
      Check the fuses down by the throttle pedal.
      Would help if we knew what year your Surf is.
        Its a 91 2.4l all the fuses ok there but can't see anything marked as 4wd fuse. Cheers.
          It probably won't be, each fuse does several things.
            Back to the drawing board then. I have switchable power on the 4wd button but nothing at the transfer box motor. The motor works as have used another battery to test it. Changed the 4wd control box and still nothing. Any ideas??
              Sorry about not replying, Would you like an electrical diagram anyway?
