Does anyone know if these are the only bits i need or do i need contacts as well?
There seems to be a lot of small parts in the Roughtrax starter refurb kit, but they cant even send one out until monday!!
So i looked for part numbers to get stuff from my local yota place!
This is copied from the sticky"
Starter Motor.....
Contacts
Allthe parts can be obtained from Toyota.
http://www.afm15.dial.pipex.com/sur...eplacements.pdf
All the starter bits are listed here;
Plunger, Magnet Switch (Solenoid) Part No. 28235-17030- £14.92
Fits 2LTE, 3L..LN13# IKZTE, 2L#, KZN130, LN108,112,85..4FC
Starter Kit, Motor Terminal (The bit the plunger hits and connects the starter motor) Part No. 28226-54220 £9.39
Starter Kit, Battery Terminal (The other bit the plunger hits) Part No. 28226-54320 £5.78
That pdf link doesn't work now either !
I really need to get it fixed over the weekend as i need it for work!!!
Alan
Starter Motor.....
Contacts
Alan
