Clicking relay noise
  • Clicking relay noise
    For the last few days I had a really annoying noise coming from under the dash at about the height of my right knee. It's been driving me nuts.
    Finally tracked it down to a relay that’s accessible just behind the very bottom of the dash, below the fuse section.
    I've removed the relay, it has the following markings:
    Relay
    TOYOTA
    90987-02012
    156700-0870
    12v
    Denso
    Any idea what it's for? So far I've checked and all work:
    All lights
    windows*
    electric aerial
    rear window
    sunroof
    AC
    4x4 drive
    horn
    stereo
    fan
    windscreen wipers (F&R)
    I've not checked (as they are not currently working anyway):
    heated rear window (never worked since I bought the truck)
    *Drivers electric window (hasn't worked for a while, think the motor needs replacing)
    Not sure what it does!!
    What colour are the wires going to the relay?
    Does it just click all the time or when you are driving/ignition on?
      Will let you know on the colours, it clicked every time i went over a bump, like there is a loose connection somewhere...
        Spare wheel carrier relay which explains why you get the clicking when you hit a bump.
          Makes a lot of sense that. What does it actually do, is it just for a warning light or something?
            Don't know but I would think it has something to do with the warning light that you would get if the carrier was not closed properly.
