Every morning rear window goes up and not down, (i've left window down overnight to test this)
If I then drive somewhere in the car more often than not the window works fine!
I have also noticed that when the rear wiper is on intermittent it stays permanently on and doesnt' pause at top of the glass. If I switch car off then back on some minutes later the wiper usually works as it should, stops in the correct rest position and also the rear then works fine.
Does this mean the most likely cause of this a rear wiper fault stopping the glass from working properly? Also, if so, where do I start? Is it a relay or a bad connection. Great truck but this is becoming hugely inconvenient when trying to load the dogs each morning!!!
Thanks in advance
Thanks in advance
