2.4 1992 Surf Ignition Barrel Replacement.
  • 2.4 1992 Surf Ignition Barrel Replacement.
    Hi Folks, can anyone tell me how easy it is to replace the ignition barrel assembly? I have recently purchased a Surf with what looks like a botched attempt at stealing it by levering out the ignition barrel. It has snapped at an alloy lug to the left and rear of the barrel (viewed from drivers seat). Is this an easy swap to replace with new or is there a lot of work involved? I will also be looking to source the lower plastic trim panel around the bonnet and petrol cap release levers, and also the trim panel around the ignition barrel itself. Can anyone help or give me some pointers?
    hi easy job ,take the steering colomn out complete ,4 bolts and wiring plugs i have a barrel lock key and all your trim £65 inc p+p email snailpaceracing@btconnect.com or 07759 272270 terry
      Hi Terry,
      I will give you a call tomorrow for those items. Thanks very much.
      PS: Assuming barrel has matched key(s) with it?
