I would like to wire up a couple of guages to the power so that when the headlights are on OR on with main beam that the gauge is illuminated.
The previous owner of my old Surf wired it up in such a way that the gauge illuminated with side or dipped headlights, but when needing full beam the gauge went out.
As I never fitted or removed any gauges to a Surf at all, are there any pointers as to where to connect a feed from? I'm going to connect up three gauges in total.
Thanks in advance!
Thanks in advance!
