AirCon
  • AirCon
    hi Guys,
    i got a strange problem with my aircon, it starts fine it cools the vehicle, but after a while it stops cooling, normal wind comes out of the vacum, i dont hear the sensor starting and stopping the compressor...
    it appears to happen after the engine gets hot to certain temperature, the temp gauge shows a normal temp...
    any ideas?
    tanks guys.
    low or getting low on aircon gas
      thanks man, i will have that checked out. it normal to happen? 'cause i had it refilled less than 6 month ago.
        Could be you have a seal going, allowing the gas to leak. If you had it refilled professionally then they should have added a UV dye to it so that they can spot where it's leaking from. Take it back where you had it done last time if possible, as they may check & top up FOC, seeing as they might have missed something last time they did it.
        Mike G
          thanks guys...
          i appreciate it.
