Speedo Swap
  • Speedo Swap
    Hi all
    does anyone know if its possible to swap the speedo gauge (only) from a cable-driven speedo cluster into an electronic cluster?
    My electronic one is knack'd for whatever reason and I've got one from ebay but the cluster arrived today and its a cable driven affair.
    And some that smile have in their hearts, I fear, millions of mischiefs
    Have a read of these threads first to see if you can fix the electronic one...
    http://www.hiluxsurf.co.uk/forums/sh...ghlight=speedo
    http://www.hiluxsurf.co.uk/forums/sh...=white+plastic
      And the results are just in from the Slovenia panel, who having dismantled the cluster, have returned a vote of ...
      ..null point!
      Hmph!
        Is the O/D light on the dash blinking every few seconds when driving? (O/D button must be pressed in by the way)
          Hi matey
          thanks for your earlier replies.
          No, I've none of the other symptoms that others are talking about with the same problems. I also dont seem to have any fault codes when i did the check.
          The speedo stopped 2 years back, briefly, but then came back ok. Then 6 months back it packed in again full-time.
          I checked the sensor as per and all seems okm but still no joy.
