Hia, any of you clever bod's out there known where the ADD relay is physically located? Why, 'cause when I select 4WD on the button the voltage is not coming off one of the VSV's and not coming on on the other!
Cheers for help in advance
Cancel that found the F*&ker! now just need the right wiring colour codes so I can test it on the bench; the blurry sketch I found on an Aussy site does not seem to match a 3.0 Gen 2.........help
