Hi all,
Got some weird things happening with the window & central locking electrics.
Sometimes the drivers window won't work at all, sometimes it works just fine, for example, on the way to the supermarket today it worked, on the way home, nothing. Sometimes the rear passenger window won't work either.
They either work totally fine or not at all, it doesn't go down & get stuck, or eventually go down after repeatedly hitting the button.
I was wondering if it's the master switch unit, so I took it out and gave it a damn good clean, but it's still the same. Could there be a problem with the circuit board in the switch unit?
Any ideas, it's driving me nuts!
