Does anyone have a wiring diagram for the standard horns on my 94 4-runner?
They're not working and I think i've narrowed it down, but want to check to see if my thinking is correct with the diagram.
The steering wheel switch works - you can hear the relay ticking.
The relay works - ^^
The fuse is fine
Both actual horns work when connected manually.
The link between the two horns also works fine.
The horn connections are OK
This leaves me with only one thing if i'm correct - the link between the relay and the horns must be bad?
Cheers, Ben
The fuse is fine
Cheers, Ben
