Folks,
Any hams out there operating HF in their 2nd gen Surf's?
I'm suffering from bad interference caused by something in the engine and I'm not sure where to start looking or how to address the problem.
The interference sounds a similar to that caused by spark plugs. The frequency at which the interfering 'pulses' occur and their intensity varies depending on how far the right foot is depressed. Its even present for about 1/2 a sec after switching off the engine! The interference is not directly coupled to vehicle speed. i.e. if doing 70mph and the right foot is lifted off, the level and frequency of the interfering pulses drops dramatically - much, much quicker than vehicle speed.
Any thoughts on common sources of interference on 2nd gens?
Truck runs perfectly.
I have a 2nd Gen, 3 ltr diesel SSRG
  I will see what info is in the forum and then perhaps start a new post.
  Connecting any-old antenna is easy - hence the suggestion of a piece of wire.  The receiver covers 1MHz to 30MHz on HF, then 144MHz and 430MHz.  The noise is mostly present across HF, hence my broadband comment.
